please retest on 1.0.9.8 and report back with your findings.
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
xm and turtle beach
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
no
If no, please describe your system here.
Aopen Mini
Lilliput 7" touchscreen
turtle beach roadie
usb xm tuner
usb gps receiver
5 in 1 obd2
phoenix gold 5 channel amp
pioneer sub enclosure and 10" shallow mount driver
radio shark
griffin powermate
Please provide any relevent information regarding the issue you have encountered.
I have a Turtle Beach Roadie sound device. I plug the audio out on the satellite tuner into the line in on the Roadie. When the input is set to Line In in the Streetdeck settings menu for the satellite radio, it switches between the media player and the satelite fine. However when it is set to Line In, the Roadie only acts as a pass through and doesn't process the sound from the sat so it is only in the front speakers and doesn't sound very good. If the input setting is to SW Synth or Wav, it sounds great (processes the sound) but it doesn't switch. On SW Synth I think it doesn't play the media at all and on WAV it plays both the sat and the music from the HD together. Any suggestions?
Jan Bennett
Jan Bennett
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
