Hey, do you have a link to the older driver? I'm having the same problem.
Alternately, SD guys -- have you figured out what's up and is a fix coming fairly soon?
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
BSOD starting Streetdeck
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
no
If no, please describe your system here.
mb896 mitx board sold on mp3car.com store w/ 915G Chipset
Celeron M 1.5
512mb DDR2
Via Envy Sound
Please provide any relevent information regarding the issue you have encountered.
With the latest Intel Graphics driver from January 07 get bsod with latest update of Streetdeck, previous worked fine. Had to load previous version of Intel drivers from OCT 06, bsod cited igfx dll file as cause. Happened right after the initial startup animation when starting Streetdeck. Just thought you'd like to know.
Its probably the background visualization. There will be a way to disable this from the command line in the next patch.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
Jan Bennett
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
