please retest on 1.0.9.8 and report back with your findings.
What version of StreetDeck is this bug report for?
1.081
Please give a basic description of the issue here.
Update hung on first upgrade from previous verison
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
I ran the update on my development machine and the first boot of SD took about 30 seconds and worked fine. I put it on the CarPC and it locked at Saving Settings (I think that is what it was - seems like it is the last step on the splash screen). Anyway, I opened task manager and it was not hitting the CPU at all. Every 20 seconds or so it'd hit 4%, then go back to 0%. SD was taking about 159 megs of mem and sitting steady so it looks like it was just off in the weeds. I ended the task and loaded it again and it booted up fine with no issues. I know this is isn't reproducable but I figured I'd mention it in case it sheds light on something else...
Jan Bennett
Jan Bennett
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
