Results 1 to 4 of 4
Thread: StreetDeck pegs the CPU and System Memory
    UV7
    UV7 is offline
    Newbie UV7's Avatar
    Mar 2007
    ...In my own little world
    What version of StreetDeck is this bug report for?
    1.0.8.1
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    After loading the 1.0.8.1 update, which completed just fine, my system runs EXTREMELY slow. The buttons take forever to display, there is a 1-2 second delay after pushing a button for its function to take place, and the system's speed seriously inhibits its ability to interpret gestures on the touch-screen.
    I toggled the system to window rather than fullscreen and was able to get a good look at the Windows Task Mangler. StreetDeck.exe is pegging the CPU and consuming 88,000K+ of memory. I tried running -nodelayload -nodelaycomp with little change. I've also run -resetconfig, but the problem persists.
    I ran the 1.0.6.3 update back over the 1.0.8.1 and everything runs great. I ran the 1.0.8.1 update again, which completed successfully, but everything started to creep again. Sure enough, StreetDeck.exe was pegging the CPU and consuming tons of memory all over again.
    I've included my log file from the latest attempt at 1.0.8.1.
    Currently, I have installed 1.0.6.3 back over 1.0.8.1 until I can figure out why SD is pegging my resources.
    Please let me know if anyone has any ideas.
    Thanks,
    UV7
    Attached Files Attached Files
    True knowledge exists in knowing that you know nothing. True wisdom comes to each of us when we realize how little we understand about life, ourselves, and the world around us.
    -Socrates
    Constant Bitrate sharpmat007's Avatar
    Nov 2006
    Washington, DC
    Have you tried setting the background to a static image? Go to Settings Page -> Color Shifting and check the box to use static image.
    If this corrects the problem it indicates that your video card cannot handle the moving background and its offloading the rendering to your cpu.
    Mitsubishi Eclipse 2006 GT
    Infill T3 running StreetDeck
    May 2006
    I pretty much have the same setup and it maxed my CPU % too until I set it to static.
    Is there a way to detect if the video card can't handle the new background features and mark it static for us? I had no idea what was going on until I came on here to find out that there's quite a few people that have run into this.
    Ken
    IS300 IBP manual
    _
    Mar 2004
    Little Elm, Texas
    UV7 - have you tried this at all?
    I will close this thread and assume it has been fixed since you haven't come back in to say otherwise.
    You can reopen the thread if you desire.
    bigpimpn79 - please make your suggestion in the suggestion thread.
    Jan Bennett
  1. StreetDeck F.A.Q.s
    By RedGTiVR6 in forum StreetDeck
    Last Post: 04-16-2007, 12:55 PM
  2. FAQ: Glossary of Terms
    By Bugbyte in forum The FAQ Emporium
    Last Post: 11-07-2006, 05:00 PM
  3. Windows Vista
    By thanatos106 in forum Software & Software Development
    Last Post: 06-28-2006, 11:56 AM
  4. Found someting interesting on E-Bay!!!
    By outragis in forum Classified Archive
    Last Post: 01-23-2006, 09:38 AM
  5. cpu to great sounding system
    By jettamasta in forum Input Devices
    Last Post: 09-14-2003, 05:01 AM
