I edited the config.xml to ignored stations. It worked fine until I restarted. Then, of course, no stations are ignored.
Please fix this or at least acknowledge it.
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
XM Ignore list doesn't update
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Since upgrading to 1.0.8.1, SD doesn't update my changes to the station ignore list. It'll be good for that session only then all channels return next time SD starts.
We haven't found a way to duplicate it on several systems that we have tried yet.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
I am experiencing the same problem. When XM reloads (after restarting) the station the ignore list is reset.
What XM device are you using? I have XM direct.
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
Jan Bennett
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
