What version of StreetDeck is this bug report for?
Please give a basic description of the issue here.
Streetdeck Bug Reporting Process
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
If no, please describe your system here.
Streetdeck **BUG** Definition:
Reproducible error using all Streetdeck supported hardware correctly.
This process was designed to eliminate the confusion of reporting a bug with Streetdeck. Bugs will only be fixed if they are listed in the StreetDeck bug forum and contain all the required information. Do not expect a bug to be fixed if it is not listed or does not contain all the relevant information. The job of StreetDeck tech support as it relates to reporting bugs is to duplicate issues and confirm that they are in fact bugs and not simply configuration errors or unsupported hardware. Please help by providing accurate information.
Please provide any relevent information regarding the issue you have encountered.
