Results 1 to 4 of 4
Thread: Digitalmods will not install
    May 2007
    What version of StreetDeck is this bug report for?
    1.0.8.1
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    no
    If no, please describe your system here.
    1.5 GHZ Mac Mini Intel running windows XP SP2 native under Boot Camp
    Please provide any relevent information regarding the issue you have encountered.
    Trying to install weather digitalmod and it simply will not install. I've tried opening, dragging onto the app, installing from the app's folder, opening from within, the app. Is this a known issue?
    Low Bitrate djjerdog's Avatar
    Jul 2006
    Milwaukee, WI
    Try starting SD, then toggling full screen, with SD still running double click on the installer for the weather plugin.
    I havent been able to get the weather mod working on 1.0.8.1, but it installed fine for me...
    Also are you running anything like min-login?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    What do you mean by it won't install? Do you get an error message when installing it? What specifically does streetdeck do when you drag and drop it onto StreetDeck?
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    _
    Mar 2004
    Little Elm, Texas
    since the OP has not come back to update us on the status of this bug, I am closing it.
    OP - if you believe this is still an issue, you can reopen this thread.
    Jan Bennett
  1. Replies: 10
    Last Post: 11-20-2006, 06:14 PM
  2. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 09:48 PM
  3. Tinyxp vs nlite vs sensible install
    By geeky_hawkes in forum WinNT Based
    Last Post: 06-15-2006, 04:55 PM
  4. Starting MM trys to install IntelPROset software?
    By sturmovik in forum Map Monkey
    Last Post: 06-03-2006, 03:20 PM
  5. windows xp install
    By Moneyfink in forum WinNT Based
    Last Post: 03-09-2005, 01:05 AM
