please retest on 1.0.9.8 and report back with your findings.
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Podcast MOD not working with 1.0.8.1
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
I while ago Chuck post a Podcast MOD http://www.mp3car.com/vbulletin/stre...ideo-blog.html
I thought it was great, and I was able to modify it to play my favorite podcasts (I don't know much about programming).
Since the SD upgrade I'm not able to play them any more, every time that I select a podcast it will take me to the general settings screen, I guess this has something to do we the way the new SD version manages the music library.
What command will I need to change in order to make it work?.
Jan Bennett
Jan Bennett
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
Works fine, thanks,
