Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Loss of Map projection, white background only - 1.0.8.1 - 1.1.1.0
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
    If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
    Jan Bennett
  2. #12
    Jun 2006
    This issue is still present! I think it is a bit daft that you close this thread after 8 days of no reply from me, yet I have not hand any replies to this problem other than try it with the upgrade!
    THe problem is exactly the same as in 1.0.8.x, but did not exist at all in 1.0.6.3! This problem has been going on long enough now I would like some kind of idea when it is likely to be fixed (particullaly as it seems related to the nav lines bug that is reported)
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    Geeky - I'm sorry that you feel it is a bit 'daft'. If we don't have you report back to us that it still isn't working in the newest release, we have to assume that it's been fixed.
    If you open a bug report, we need you to follow up on it when responses are posted, otherwise, our developers are spending time in areas where they don't need to.
    You have reopened the issue, as has been stated that you can do.
    We cannot leave bug reports open indefinitely without responses from the bug reporters.
    Jan Bennett
  4. #14
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    There is also no system info in your user profile so we have no idea what hardware you are using. We want to get these bugs fixed, but we really need all of the data to help. We should have really asked for this on 5-25. Please bear with us while we are adjusting to the new bug reporting process.
  5. #15
    Jul 2006
    Baltimore
    Reproducing the issue
    I am having some trouble finding the graphics card you are using. Please call my ext. directly and I can help you work through the issues you are having.
    Adam Engel
    Streetdeck QA
    410-526-2852 ext. 205
  6. #16
    Jun 2006
    Sorry, im in the uk so not able to call to discuss this issue, however I have made a video attached of the issue "at work".
    As far as machine spec, its a celeron 1.6ghz, 512mb ram, sis mirrage graphics 661 card, DX7H/W and DX9s/w, also got an 80gbHDD and running 800x600 @ 60hz in both 16bit and 32 bit (with no change to the problem).
    Windows XP SP2, full install with just a few standard tweaks to reduce boot time. As mentioned before this issue was not present in 1.0.6.3 (appart from the vertical lines anyway), but has been an issue in the last two versions of SD.
    I will post a link to the SIS site if required indicating some more details about the card.
    Hoep this helps as its damn frustrating the nav not working!
    Cheers guys
    Attached Files Attached Files
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    geeky - you can post your PC specs under your user name if you would like.
    See here for instructions: http://www.mp3car.com/vbulletin/anno...r-profile.html
    It makes things easier for others trying to help you out.
    Jan Bennett
  8. #18
    Jun 2006
    Specs added, hopefully this bug can be fixed soon!
  9. #19
    Jul 2006
    Baltimore
    Are you using a Europe version of map point since you are in the UK?
  10. #20
    Jun 2006
    yes I am running mappoint europe and from the video you can see it works not in full screen mode.
  1. iGuidance Hacks
    By pbarrette in forum GPS
    Last Post: 12-28-2007, 04:06 PM
  2. white background in flash location?
    By addertay in forum Road Runner
    Last Post: 11-06-2007, 07:05 PM
  3. Loss of Map "projection" on upgrade 2 1.0.8.1
    By geeky_hawkes in forum StreetDeck
    Last Post: 05-25-2007, 11:59 AM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
