Loss of Map projection, white background only - 1.0.8.1 - 1.1.1.0
What version of StreetDeck is this bug report for?
1.0.8.1 - 1.1.1.0
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
After a clean install and upgrade from 1.0.6.1, i lost the map projection in SD. All that was drawn was the car present position, and a white background at all zoom levels and with all virtual earth modes.
If the SD instance was run in windowed mode (not full screen), then the map would appear, but once full screen was selected the map would disappear again.
After several adjustments made I discovereed that the map could be gained with 800x600 and 16bit colour depth. 1024x768 or 32bit would not work in full screen mode
