Disappointly I appear to already be running DX9 and my attempt to update it made no difference.
I am really getting confused about what is going on. Can someone else post the display settings they are running SD at?
I am running 800x600, 16bit (if i use 32 I get no SD visable at all but can here my music playing). The map is only visable if i run SD windowed, yet before in version 1.0.6.3 it all worked fine?
Im pretty confused as to what has been changed in the new version as its not really very helpful to have SD without any navigation.
Interstingly, for the people that have reported the Map turning into "Lines" at certain times, i think this is related to the same issue. I have been playing with SD windowd, and if i enlarge it to the edge of the screen then the map turns in to random lines with SD at about 3/4 screen size. Anything beyond this then the map disappears totally...
LinkBack URL
About LinkBacks
