Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Display settings not saved
  1. #21
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    This appears to be caused by T3devControl.dll being present in an install on a non-Infill platform. If your not running on an Infill T3 or G4. You should delete the file T3devControl.dll and the problem shoudl go away. You may need to create an empty dummy file in its place to get around the automated installer issues.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  2. #22
    _
    Mar 2004
    Little Elm, Texas
    I've just tested this on my laptop with 1.0.9.8.
    With this update, I've noticed a bunch of pink text at the bottom that wasn't there before.
    Came up with something like 25 notices before SD opened fully.
    However, this issue does appear to be fixed now.
    As soon as someone else can confirm, I will close this issue.
    Jan Bennett
  3. #23
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    my fps settings and 16x9 vs. 4x3 settings now are successfully saved during standby and restart of SD with 1.0.9.8
  4. #24
    Jan 2004
    Quote Originally Posted by S4Per View Post
    If you didn't delete T3DevControl.dll, you probably should as it still tries to use it if its there, but will fail after a number of seconds and lengthen your start time.
  5. #25
    _
    Mar 2004
    Little Elm, Texas
    Issue closed.
    Jan Bennett
  6. #26
    pim
    pim is offline
    Mar 2006
    The Hague, the Netherlands
    display format not saved
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    Display format under settings->general->display options is not saved. It always starts with "normal (4x3)".
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    no
    If no, please describe your system here.
    Non mp3car.com Infill G4
    Please provide any relevent information regarding the issue you have encountered.
    Demo version
  7. #27
    _
    Mar 2004
    Little Elm, Texas
    threads merged. Issue still closed.
    Jan Bennett
  1. V1 Virtual Display : Skinnable Valentine One to PC Software
    By zPilott in forum Software & Software Development
    Last Post: 01-18-2013, 05:11 PM
  2. Planning Phase help for ceiling mounted display
    By HullBreach in forum Newbie
    Last Post: 04-07-2007, 04:31 PM
  3. Centrafuse XLE RC1 Release Notes
    By veetid in forum Centrafuse
    Last Post: 07-12-2006, 03:48 PM
