Ditto
What version of StreetDeck is this bug report for?
1.0.9.6
Please give a basic description of the issue here.
Display settings not saved
Phone Information
Please list your phone carrier you are using to test with.
Please list the manufacturer of the phone you are using to test with.
Please list the model of the phone you are using to test with.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Change video settings (e.g frame rate from 1 fps aspect ratio from 4x3)
Choose save.
Save to Disk.
Exit SD
Start SD, fps is back to 1fps and 4x3
Please provide any relevent information regarding the issue you have encountered.
Same issue as 1.0.9.5.
Ditto
I need a log, I can't duplicate this.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
Jan Bennett
it's in general - display options. next time it happens i'll send a log.
Able to recreate.
Log file from when I made the change and exited and from when I restarted SD attached.
this was on the G4.
Jan Bennett
Here a files which should be verbose logs of:
1) start, setting display fps/16x9, save, and exit.
2) restart where settings have not been saved.
This is still not working in 1.0.9.7. Exact same thing as .6. Set to 45 fps and 16x9, exit, reload, and it is reset to 1 fps and 4x3.
