What version of StreetDeck is this bug report for?
1.0.9.8-1.1.0.0
Please give a basic description of the issue here.
SD freeze when using browse in navigation module
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
select the navigation module. click on browse. click on any of the arrows. this freezes up sd and eventually would lead to sd closing. I had the music module playing as well when i was doing this
SD has only NOT frozen one time while using this feature
Please provide any relevent information regarding the issue you have encountered.
