I have used this feature extensively now. On our 6 hour drive to Orange, TX I used it a great deal and never once had it crash on me.
What version of StreetDeck is this bug report for?
1.0.9.8-1.1.0.0
Please give a basic description of the issue here.
SD freeze when using browse in navigation module
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
select the navigation module. click on browse. click on any of the arrows. this freezes up sd and eventually would lead to sd closing. I had the music module playing as well when i was doing this
SD has only NOT frozen one time while using this feature
Please provide any relevent information regarding the issue you have encountered.
Jan Bennett
This feature almost always freezes SD the first time I click a direction. A couple times I have moved two or three times before it froze.
I have yet to see this feature work for more than two browse clicks. As soon as I press one of the arrow keys in borwse mode it freezes, I will collect a log as well.
Please increase the priority on this as 3 of 4 does not sound right
i am having the same issue. It freezes each time i click one of the arrows in the browse menu.
The severity of issues is not just based on the issue at hand but the other issues that are only plate of the developers as well.
Many things have to be taken into consideration when assigning severity, as such, the severity of this issue is appropriate at this time.
Jan Bennett
I noticed that when I turn off Smooth Map Scroll option in the Navigation Options it seems to work much better. I still saw it crash, but only once on a very extensive use test.
Mark
I am happy to see this wasnt only happening to me, If i goto browse mode I cant do anything. If i touch the screen to a location SD locks up, if i click any of the on screen arrows SD locks up.
This is happening to me as well. Sometimes I can get a couple of clicks before it locks up.
I just figured out this only happens with the virtual earth mode turned on. If I have it in normal map mode I can browse no problem.
