SD freeze when using browse in navigation module - 1.0.9.8 - 1.1.0.9a
What version of StreetDeck is this bug report for?
1.0.9.8 - 1.1.0.9a
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
select the navigation module. click on browse. click on any of the arrows. this freezes up sd and eventually would lead to sd closing. I had the music module playing as well when i was doing this
Please provide any relevent information regarding the issue you have encountered.
1 Attachment(s)
SD freeze when using browse in navigation module - 1.1.0.0
1.1.0.0
Yes
Yes
I am reopening this as i do have a log file of the issue. My zipcode is 64117. not sure if it will be relevant but my gps was in this zipcode when it happened. if you need any more info, please let me know
thanks
