bumping to the top after updating all other threads.
What version of StreetDeck is this bug report for?
1.0.9.8 - 1.1.0.9a
Please give a basic description of the issue here.
SD freeze when using browse in navigation module
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.select the navigation module. click on browse. click on any of the arrows. this freezes up sd and eventually would lead to sd closing. I had the music module playing as well when i was doing thisPlease provide any relevent information regarding the issue you have encountered.
Jan Bennett
This has happened to me several times as well. Not every time, but a lot of the time.
- Mike
the developers need logs. please post your logs so that they can help determine where the problem lies.
Jan Bennett
bembowe and thepunkerguy - please post your logs. Without them this thread will have to be closed.
Jan Bennett
Adam/Chuck - updates?
Jan Bennett
I have had this issue in the past. The development team is working on how to exactly reproduce this issue. Please post your logs and describe exactly what you were doing before SD crashes to help us troubleshoot this issue.
due to a lack of follow-up from the OPs and no logs, we cannot continue supporting this bug.
If either of you have a log to post, you can reopen this thread and post them. Untill then, we have to consider this a non-issue.
Jan Bennett
1.1.0.0
Yes
Yes
I am reopening this as i do have a log file of the issue. My zipcode is 64117. not sure if it will be relevant but my gps was in this zipcode when it happened. if you need any more info, please let me know
thanks
rather than create a new bug report, please just open the existing one in the future. I've merged these two threads. This helps keep all the information in one place.
Just to add, I have used the browse feature on my laptop and in the car without issues.
Jan Bennett
