Results 1 to 10 of 10
Thread: Problems resuming from Hibernation - 1.0.9.8
    Jun 2007
    What version of StreetDeck is this bug report for?
    1.0.9.8
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    Resume from Hibernation, wait a few seconds and tap screen or move mouse.
    Please provide any relevent information regarding the issue you have encountered.
    Problem started when I upgraded from 1.0.8.1 to 1.0.9.8. After resuming from hibernation Streetdeck will resume normally in the GPS Screen with with music playing. Everything works well until the first time I touch the screen. When I touch the screen or move the mouse for the first time the screen it fades dark for a second and the music restarts again to the exact point where StreetDeck first resumed. The auto music index will also run again. Its like it is resuming twice.
    This only happens once on the first time I touch the screen. After that point StreetDeck works as expected.
    Attached Files Attached Files
    _
    Mar 2004
    Little Elm, Texas
    Chuck/Adam - updates?
    Jan Bennett
    Jul 2006
    Baltimore
    Do you have the settings in SD and Control Panel power settings set to hibernate?
    Jun 2007
    No, Only SD is configured to Hibernate.
    Jul 2006
    Baltimore
    Try and set both windows and SD to hibernate when car is shut off. I am still having trouble replicating this issue. If you could get screen shots or video with a log file that would help troubleshooting greatly.
    _
    Mar 2004
    Little Elm, Texas
    MikeD610 - please let us know your results after following Adams post.
    Jan Bennett
    Jun 2007
    sorry... I’ve been extremely busy for the last week. I will post more data tomorrow evening.
    Thanks again
    _
    Mar 2004
    Little Elm, Texas
    any updates?
    have you updated to the newest release? 1.1.0.0?
    Jan Bennett
    Jun 2007
    This problem was resolved with version 1.1.0.0. What ever you did worked :-)
    Thanks again for the support!
    _
    Mar 2004
    Little Elm, Texas
    issue resolved. thread closed!
    Jan Bennett
  1. Replies: 23
    Last Post: 10-22-2006, 03:06 AM
  2. Problems resuming from stand-by
    By weekendowel in forum FreeDrive
    Last Post: 10-25-2005, 03:26 PM
  3. Replies: 4
    Last Post: 10-10-2005, 12:56 PM
  4. Bluetooth dongle hibernation problems
    By Sonicxtacy02 in forum Wireless Communications
    Last Post: 09-02-2005, 09:00 AM
  5. hibernation problem
    By btbe in forum Road Runner
    Last Post: 04-13-2005, 06:30 AM
