Chuck/Adam - updates?
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
Static noise in music after hibernation
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.Resume from hibernation. Happens every 4 or 5 times after I resume.Please provide any relevent information regarding the issue you have encountered.
Every few times I resume from hibernation there is a constant loud static/popping noise in the music. If I restart SD or hibernate again the noise goes away.
Jan Bennett
Are you using the internal sound card?
No, it does have an internal sound card but I am currently using an external Turtle Beach micro sound card.
Does this popping sound like a digital scratch or a grounding issue hiss. The reason I ask is that with external USB sound cards there is an issue with the number of devices plugged into a single controller which causes a digital popping in the background of music. The other issue could be the targus power supply you are using could be creating a ground loop with your amplifier. The solution is to get a ground loop isolator ($15) or spread the distance between the targus PSU and the amplifier. If these are not the issues can you record the audio and post it for better trouble shooting. Hopefully this helps!
This is more of a constant bad digital scratch sound. This is defiantly not a grounding issue (I worked those out a long time ago :-)). I only hear this problem every few times I resume from hibernation and when I restart SD the problem instantly goes away. When you say there is an issue with the number of devices plugged into a single USB controller, do you mean a SD issue or Hardware/driver issue?
MikeD610 - we cannot continue supporting this bug if we do not have any followup.
Please provide some response for us within 24 hours or this bug report will be closed.
Jan Bennett
sorry... Ive been extreamly busey for the last week. I will post more data tomorrow evening...
Thanks again
any updates?
have you upgraded to the newest release? 1.1.0.0?
Jan Bennett
