Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: resuming from hibernation in test mode, the Testmode confirmation dialog - 1.0.9.8
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    What version of StreetDeck is this bug report for?
    1.0.9.8
    Please give a basic description of the issue here.
    When resuming from hibernation in test mode, the Testmode confirmation dialog box appears and must be dismissed two (or sometimes three) times before SD is usable.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes.
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes. By resuming from hibernation.
    Please list the steps required to recreate the issue you are reporting.
    Resume from hibernation.
    Please provide any relevent information regarding the issue you have encountered.
    I have multiple usb input devices installed...could that be an issue?
    • USB mouse
    • USB joystick
    • Griffin Powermate
    • Lilliput 629 touchscreen...drivers supplied by manafacturer
    _
    Mar 2004
    Little Elm, Texas
    I fixed the title. I'll let Chuck or Adam comment on the bug.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Chuck/Adam - updates?
    Jan Bennett
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    just fyi - i use testmode 100% of the time and have not run into this myself. I use a touchscreen, rotary encoder (ccStick) and RF keyboard (amongst other USB devices)
    Nov 2006
    resume from hibernation in test mode
    I certainly have this problem as well. My previous version (1.0.6.3) did not.
    Quote Originally Posted by S4Per View Post
    Apr 2007
    Pawling, NY
    Same here after the 1.0.9.8 update.
    Apr 2007
    I have the same problem after update as well, its quite annoying! I thought it was only supposed to come up when you started the program the first time, not on a hibernate resume. And having to hit it 2-3 times sucks too!
    - Mike
    Jan 2004
    Seattle, WA
    it will always come up, on resume also, not just start. hitting it 2-3 times though is certainly not by design.
    Dec 2005
    Dallas, Texas
    ...and it will frequently stop the current track after the second press. The track playing before hibernation begins playing correctly, but then stops. That's annoying as well.
    Apr 2007
    Aptos, California
    I too have this problem.
  1. Quest for 800x480
    By ptk in forum LCD/Display
    Last Post: 01-04-2010, 11:42 AM
  2. Static noise in music after hibernation - 1.0.9.8
    By MikeD610 in forum StreetDeck Bug Reports
    Last Post: 08-07-2007, 11:06 AM
  3. Problems resuming from Hibernation - 1.0.9.8
    Last Post: 07-26-2007, 04:01 PM
  4. Night Mode Issue - 1.0.9.8
    By Sinabl in forum StreetDeck Bug Reports
    Last Post: 07-18-2007, 10:43 AM
