Results 1 to 10 of 10
Thread: Hibernate does not function properly - 1.0.9.8
    Sep 2006
    What version of StreetDeck is this bug report for?
    1.0.9.8
    Please give a basic description of the issue here.
    Resume from Hibernate does not function properly
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Infill T3
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    When I turn of the car power the T3 closees as usual. When I turn the car back on the T3 turns on as usual acting as if it is resuming from hibernation. Once fully awake from hibernation it goes into shut down and shuts itself down. I then have to manually power up the T3 via the power button
    Please provide any relevant information regarding the issue you have encountered.
    This only happened once I upgraded to latest version of SD. I can manually close SD into hibernate and it works fine.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Is your shutdown option set to hibernate in shutdown settings? Does it work if you set it to standby instead?
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Resume from hibernation triggers a full restart (VISTA) - 1.0.9.8
    1.0.9.8
    Phone Information
    Please list your phone carrier you are using to test with.
    N/A
    Please list the manufacturer of the phone you are using to test with.
    N/A
    Please list the model of the phone you are using to test with.
    N/A
    Yes
    Yes
    1. Streetdeck is open and playing XM
    2. Turn off the ignition
    3. Carnetix P2140 running PSUMoni successfully sends the pc into Hibernate via USB command.
    4. Come back to the car later, start it, initiate resume from hibernation
    5. PC resumes, goes to the desktop, then (approx. 5 secs after desktop appears), before Streetdeck is able to resume, the pc shuts down and restarts.
    6. Upon restart, Windows gives the message about shutting down unexpectedly.
    Please provide any relevent information regarding the issue you have encountered.
    If I turn off the ignition WITHOUT SD running, the pc will resume from hibernation successfully with no issue.
    Sep 2006
    I switched it to standby and it still does the same thing oddly enough.
    Jan 2007
    New Orleans, LA
    Looks like this guy is experiencing the same thing with his T3:
    Sep 2006
    I think I might have solved this one. I disabled Hibernate and rebooted a few times and tested standby to no avail.
    I then re-enabled hibernate and the in advanced settings made sure the settings for power button and sleep button both were set to hibernate. The I set SD back to hibernate.
    I have tested it twice today and it's worked properly both times.
    _
    Mar 2004
    Little Elm, Texas
    threads merged.
    Thanks for the link.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    vitaminR - can you confirm that this worked and still works?
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    vitaminR - we need confirmation before we can continue.
    If I have not heard back within 24 hours, I will have to close this bug report.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    thread closed.
    Jan Bennett
  1. 1.7 Progress report
    By veetid in forum Centrafuse
    Last Post: 04-28-2006, 11:14 AM
  2. Resume after hibernate scrutinized
    By ldave in forum PowerVoice
    Last Post: 02-10-2006, 12:04 AM
  3. Hibernate takes longer than 45 secs, big problem!
    By davem in forum General Hardware Discussion
    Last Post: 11-17-2005, 02:47 PM
  4. CarPuter wont hibernate now.
    By djtrickee in forum Power Supplies
    Last Post: 01-12-2005, 02:36 PM
  5. Need help with setup..laptop, hibernate, external hdd
    By Kato in forum General Hardware Discussion
    Last Post: 06-25-2004, 01:43 PM
