done. still there. updated first post.
Please retest on 1.0.9.9 and report back with your findings.
Jan Bennett
I have tested this and got the same issue on all testing units. I will report this to our engineers and see if there is a simple fix.
I have sent adam an email about this issue.
However, I will say that this is going to be a lower priority item for chuck right now.
Jan Bennett
I will try and test this in our car tonight with the newest update (1.1.0.0). f you wouldn't mind doing the same I'd appreciate it.
Even though this area was not specificially thouched by the developers, there is a chance it could be inadvertantly affected.
Please report back with your findings.
Jan Bennett
I can confirm that cross fading doesn't work here either.
This issue has been reported internally; however, because of the nature of this issue, it will not be at the top of the list of priorities for the developers.
Jan Bennett
tested as well on 1.0.9.9 and no dice in the car.
I have not updated the car to the newest release because of the issues I had with it on my laptop.
Jan Bennett
I have tested with 1.1.0.0a. Crossfading does not work. This is a lower priority issue but we are working on it. I will submit a change request to chuck. Thank you for the testing and feedback.
Threads merged since this is the same issue.
Jan Bennett
