1 Attachment(s)
Cross fading does not work - 1.1.0.0a
What version of StreetDeck is this bug report for?
1.1.0.0a
Please give a basic description of the issue here.
Phone Information
Please list your phone carrier you are using to test with.
Cingular
Please list the manufacturer of the phone you are using to test with.
HTC
Please list the model of the phone you are using to test with.
S620 (Excalibur)
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Go into music settings
Enable cross-fading, set to 5 seconds, save settings
stop/start media, or even exit and restart SD
cross fading does not occur.
Please provide any relevent information regarding the issue you have encountered.
Not sure how WMP cross fading settings are related. I can enable there, and play media in WMP and it works as expected.
Crossfading does not work. - 1.0.8.1 - 1.1.0.0
1.0.8.1 - 1.1.0.0
Yes
Yes
Crossfading is enabled in the Music Settings. Songs simply do not crossfade. It is certainly not an issue with dead air at the end or beginning of tracks as I have experienced this with hundreds of songs.
The notes for the 1.0.5.8 updated stated that Crossfading support was there. I do not recall what version I was running prior to 1.0.8.1, but crossfading did not work in that previous version either. I do have 1.0.9.8 installed on my development system but have not been able to determine if crossfading is working in that version. My media volume reverts to zero and will not allow me to change it. I suspect this may be a "security" feature to prevent people from using the development environment as a media player. If that's not that case, then please advise what I can do to recreate the non-crossfading issue in my development environment. I have refrained from updating my 1.0.8.1. carpc to 1.0.9.8 due to the issue with StreetDeck not staying in night mode, so at this point I cannot determine if crossfading is working in 1.0.9.8.
This issue was discussed in this thread: http://www.mp3car.com/vbulletin/stre...ss-fading.html but there was no apparent resolution to that thread, so I am reporting it in the bug subform as well.
