Does it do it in windows media player alone?
What version of StreetDeck is this bug report for?
1.0.8.1 - 1.1.0.0
Please give a basic description of the issue here.
Video Slows Down Slightly / Audio Sounds Stretched
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
No
If no, please describe your system here.Windows XP Professional, Via 2.0Ghz, 1gb Ram, 120gb SATA Hard Drive, M2-ATX, Onboard Sound and Video, etc...Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.Play a movie and after about 4-5 mins of watching it, you'll notice that the voices start to deepen and the video slows down. Usually won't get better until a system restart.Please provide any relevent information regarding the issue you have encountered.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
Nope, it only happens in StreetDeck. Media Player has no problem.
Guitar3dt - you can add your CarPC specs under your user name by following this link (if you so desire that is): http://www.mp3car.com/vbulletin/anno...r-profile.html
Jan Bennett
Hi Jan,
Thanks for the heads up. I might just do that. On a side note, I sent you an email about the 1.0.9.8 update fixing the queue doubling after hibernation problem. I saw the thread had been closed but wanted to confirm that it did in fact help.
Thanks again,
Tim
i also have that video playback issue, with avi files. The audio gets out of sinc with the video.
Jan Bennett
I sent it to both of them in your profile.
Either way, that's really all that I had to tell you....haha.
Tim
Does the issue with AVI happen in WMP 11? I have had some avi files do this in the past.
not as best as i can tell. seems to be a streetdeck only issue. i'll look into it further just to be sure.
