Problem still exists in 1.1.0.0 under Vista.
While this issue has not directly been addressed by the developers, I will recomend retesting with the latest release (1.1.0.0) and reporting back with your findings.
If the functionality has changed, we need to know about it.
Jan Bennett
Problem still exists in 1.1.0.0a under Vista.
Just wanted to post an update on this. Creative released an updated driver for this sound card. I installed it, and the issue unfortunately still exists.
The problem is definitely related to the fact that there is no choice for "S/PDIF In" under the "Volume" choice in Sat Radio settings (S/PDIF In is the input on the sound card that the XM unit is plugged into. In XP, there IS a choice for it, and everything works the way it is supposed to. With Vista's new sound engine, Streetdeck isn't seeing the SPDIF In level for some reason. I can get to the SPDIF In level in Windows Sound Mixer, and as stated in post #3, it mutes fine when I mute it in the Windows Sound Mixer.
So we just need to get Streetdeck to work nice with the new Windows Mixer in Vista.
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
XM Module
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
DELL C840 Laptop
2.00 GHz Pentium 4
768 MB RAM
40GB HDD
CREATIVE LABS SOUNDBLASTER 2 AUDIGY ZS NOTEBOOK
GEFORCE 4GO 64MB VIDEO CARD
XM PCR
WINXP PRO
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
When i run the XM module, the wave line gets muted and when i go to the music module and select a song, the XM does not stop and i cant hear any music from the music module either (due to wave being muted automatically when the xm module is run). The only way around it is to exit out of streetdeck, unmute the wave and sometimes take the slider all the way to the top (SD brings it to the middle sometimes) and then run SD again.
It appears that in this version, i can only operate one module before having to go back to windows to change settings.
Please provide any relevent information regarding the issue you have encountered.
See above. I'm using XMPCR
If you haven't filled out your CarPC specs in your Profile, you need to list them in the bug report. Most importantly, your sound card and operating system is needed here for this particular issue.
Anyone else able to recreate this issue?
And to back up what Nola111 has posted (thanks Nola111) - you answered 'yes' to the carpc specs thing, but you don't have anything listed there.
We need this information and most likely a log file as well before we can go any further.
Jan Bennett
See above.
Sinabl - thanks for the update. This thread might be of interest to you:
http://www.mp3car.com/vbulletin/anno...r-profile.html
Jan Bennett
