The T3 tuner was made for Korean stations. I will have our engineers look into this issue.
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
am band off by as much as 100khz
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Please provide any relevent information regarding the issue you have encountered.
am band is off by as much as 100khz, for example am640 is now am740 on t3 band.
1.1.0.0
AM stations either no longer come in at all or are off by up to 100KHz
Yes
Yes
Activate either the AM/FM radio or the new "Radio" and try and listen to any AM station. The "bug" occurs everytime, regardless of where I am located, and regradless of if the G4 is coming out of hibernation or a fresh reboot...ever since I updated to 1.1.0.0. (I am unsure as to what I was upgrading from, I ordered my G4 on 7/4/07 and received it one week later if that helps you deteremine what version you were shipping preinstalled)
After updating to 1.1.0.0 most AM radio stations are completely static, and some that do come in can be way off. For example (in the Metro-Balitmore area) AM 680 no longer comes in at all. When I have the dial set to AM 1090 I am picking up AM 1190. AM 1500 comes in, but not as strong. The two or three FM stations I listen to (91.9, 95.1, and 103.5) appear unaffected. Upon the suggestion of naquel (http://www.mp3car.com/vbulletin/1098013-post6.html) I installed an older version (1.0.8.1) and the problems went away and the AM stations returned.
No error messages were ever given. I am not using the developers mode, but am using -testmode. The only digitalmod installed by me is the GPS Gas Prices.
threads merged since they are reporting the exact same issue.
Any updates on this Adam?
Jan Bennett
Internally, no one has been able to reproduce this issue on their G4s, in Baltimore even.
This seems to be a machine specific issue.
Jan Bennett
Is the antenna you are using powered? I am not able to get a strong signal on the bench here. it stops on some stations that have no sound? I will see what I get on the ride home. can you post a log file?
I am not using a powered antenna, worked fine when I rolled back the update though... Where would I get the log file for this from?
_______________________________________________
All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
The same place where all log files are located. http://www.mp3car.com/vbulletin/stre...where-log.html
There is not a log file for each piece of hardware, just an overall log file for StreetDeck.
Jan Bennett
I've been out of town (and 8 states away from my car) all week. I fly home this weekend and I'll get my logs up for you. Thanks for your attention to this.
The AM works but the stations are very "iffy". I understand the issues here and I will report this to chuck for further testing.
