Results 1 to 6 of 6
Thread: SD failed to rume from standby - 1.0.9.8
    Registered User
    What version of StreetDeck is this bug report for?
    1.0.9.8
    Please give a basic description of the issue here.
    SD failed to resume from standby
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    No
    Please list the steps required to recreate the issue you are reporting.
    Please provide any relevent information regarding the issue you have encountered.
    On resume from standby the screen went blank, but when i used a keyboard to pull up the taskbar i was able to see the Streetdeck encountered and error dialog. This is the first time i ran into this problem, it was more common in the last release.
    Attached Files Attached Files
    Jul 2006
    Baltimore
    Thank you for reporting this issue. I am trying to recreate this issue on our testing machines. I will send this log to our engineers for further diagnosis.
    Registered User
    No problem
    _
    Mar 2004
    Little Elm, Texas
    Kalt - please update to 1.1.0.0 and report back with your findings. While the issue was not directly addressed with the newest release, we need to know if functionality has changed.
    Was this just a one time issue? Are you still having this issue?
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    bump - I need to know if this issue continues to happen or if it was just a one time issue.
    If I don't recieve a response, I will be forced to close this bug report.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Thread closed.
    Jan Bennett
  1. Replies: 32
    Last Post: 03-17-2008, 10:53 AM
  2. SD Won't run with voice - 1.0.9.8
    By marchello2000 in forum StreetDeck Bug Reports
    Last Post: 07-25-2007, 08:56 AM
  3. Replies: 3
    Last Post: 06-29-2007, 06:12 AM
  4. Replies: 7
    Last Post: 07-01-2005, 03:29 PM
