Results 1 to 10 of 10
Thread: won't start - 10.9.8
    Jul 2005
    What version of StreetDeck is this bug report for?
    10.9.8
    Please give a basic description of the issue here.
    won't start
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    i had an older trial version of streetdesk installed which i never really used, so i don't even know which version it was. the trial had expired. i ran fine, although i didn't really test is too much.
    i just purchased, downloaded and installed the latest version. when i try to run it, it gets as far as "applying settings", then it crashes and brings up the streetdesk error report window. the ok button in this window doesn't work.
    i tried uninstalling and removing every reference to streetdesk in the file system and in the registry, then rebooting and reinstalling. no luck.
    Please provide any relevent information regarding the issue you have encountered.
    Jul 2006
    Baltimore
    Can you please post a log. This is located in the streetdeck my documents folder. Thank you
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Check your video card drivers are up to date, i just had that cause this on my system.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Jul 2005
    webdog, i tried updating, but no luck. thanks anyway!
    streetdeckace, log attached...
    mkm
    Attached Files Attached Files
    Jul 2006
    Baltimore
    Thank you. I am working on how to replicate the issue. If you have any other findings please let me know.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    run with -AllowMediaDuplicates
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Jul 2005
    that worked! what exactly does this setting mean?
    Apr 2007
    Moscow, Russia
    Quote Originally Posted by manishie View Post
    StreetDeck manual, page 4:
    AllowMediaDuplicates - Disables checking for duplicate items when indexing music
    Jul 2006
    Baltimore
    If you have more than one copy of a song.
    _
    Mar 2004
    Little Elm, Texas
    thread closed!
    Thanks for the responses Adam!
    Jan Bennett
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 10:44 PM
  2. Failed Hiding of Start Bar, Minimize Errors
    By DaRacerz in forum RR Bug Tracker
    Last Post: 11-04-2005, 05:36 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. Can't get MediaCar to start up with windows
    By EuroFan in forum MediaCar
    Last Post: 10-19-2004, 04:48 PM
  5. donīt start
    By martin83 in forum Power Supplies
    Last Post: 09-13-2004, 03:24 PM
