I can report that this is an issue on my laptop.
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
Flac playback does not show song duration
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
No
If no, please describe your system here.
Infill T3Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Play a Flac file.Please provide any relevent information regarding the issue you have encountered.
Flac playback works correctly, however none of the songs show how long the song is.
Jan Bennett
1.0.9.9 - 1.1.0.0a
FLAC files don't show time or spectrum analyzer
Phone Information
Please list your phone carrier you are using to test with.n/aPlease list the manufacturer of the phone you are using to test with.n/aPlease list the model of the phone you are using to test with.n/aIs the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
No
If no, please describe your system here.Fujitsu Laptop A6010Intel Core 2 Duo T5500 (1.66GHz, 2MB L2 Cache, 667MHz)Windows XP Pro SP22GB RAM (1GB x 2)120GB P-ATA 4200RPM hard driveIntel Graphics Media Accelerator 950Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.Index files and go to play a .flac file. When it comes up, it plays fine, only it doesn't show any time information or any spectrum analyzer information.Please provide any relevent information regarding the issue you have encountered.
I've registered the MIME type to audio for .flac files.
I have the codec installed as well.
Jan Bennett
Does the visualization and spectrum analyzer work in WMP?
yes, they do.
as does time.
since I realize that you probably don't have any .flac files to test with, I've attached a .flac file in a .zip folder (since .flac isn't an upload type that's allowed - no need to allow it for one upload).
Jan Bennett
updated: still an issue in 1.1.0.0a
Jan Bennett
update - I just added about 75 gigs of flac files to my car. I reindexed in sd then restarted.
I still don't havethe total son time but I do have the spectrum analyzer....more whe i'm not driving
Threads merged since they are the same issue.
Jan Bennett
I believe the the issue is in the loading of those items into memory. If you have long list try the same issue with only one file. and report back. I will see if I can recreate.
Chuck has told me that total time on FLAC files is a known limitation of the library we are using.
