Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 43
Thread: DVD Error - 1.1.0.0 - 1.1.0.9 - (Vista)
  1. #31
    Aug 2007
    Western NY
    Quote Originally Posted by Mazdaspeed View Post
    my dvd playback did not work in XP, until I ended up uninstalling WMP11, and downgrading to WMP10.
    for whatever reason, that turned out to work for me. Probably doesn't help though.
    I'm running VIA EX15000G, onboard video, onboard sound.
    Didnt work in WMP 10 for me either.
    'Burb-puter - worklog
  2. #32
    _
    Mar 2004
    Little Elm, Texas
    Please retest with the latest release (1.1.1.0) and report back with your findings.
    Jan Bennett
  3. #33
    Dec 2007
    Los Angeles
    tested with 1.1.1.0 and it does not work...
  4. #34
    Feb 2007
    Prattville, AL
    Update...DVD still doesn't work and Nav fails to initialize as well... revervted back to 1.1.0.0.....Nav works again....DVD does not
  5. #35
    Dec 2007
    Los Angeles
    bump for DVD functionality in Vista...
  6. #36
    Sep 2007
    Arizona
    having similar dvd initialization problem in XP
    I am having the same problem in XP pro. all requisits are installed but still fail on dvdrender
    i have posted a verbose log
    please advise. working with trial version currently
    Attached Files Attached Files
  7. #37
    Dec 2007
    Los Angeles
    bump... what is the status of this bug?
  8. #38
    Dec 2007
    Los Angeles
    bump again. Next bump will be to the BBB
  9. #39
    Dec 2007
    Los Angeles
    FUKC streetdeck
  10. #40
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by tek818 View Post
    FUKC streetdeck
    But the following was posted way back in December...
    Quote Originally Posted by god_of_cpu View Post
    DVDs work on Vista in StreetDeck. It is highly dependant on your video card though. You must have a video card capable of supporting the VMR for DVDs which is the old way of doing it in XP. This works on one of the vista test machines here, but does not on the other. Vista now supports playing DVDs through the EVR which is incompatible with the VMR. Unfortunatly, because of a bug in the visual studio compiler we use, we can not add support for the EVR until a patch is made or we do a major work around.
    Not that you don't have a point...one would expect a reply or two to a bug reports thread that's been bumped four times over the past three months...but also you never posted regarding whether or not your video card was capable of supporting VMR in Vista. So, I don't know why you expect resolution on this when the answer (even if it's not the most satisfactory answer) was posted before you ever posted.
  1. What's up with Vista?
    By Artificial in forum StreetDeck
    Last Post: 11-29-2007, 10:19 AM
  2. Mp3 Dvd
    By stinkyfax in forum Newbie
    Last Post: 09-23-2007, 07:12 AM
  3. House dvd player in the car & Innotek ebay screen? hmm
    By thesupe87 in forum General MP3Car Discussion
    Last Post: 09-07-2005, 11:30 AM
