This is what you suggested in the beginning.. This isn't working as mentioned already..........
Please come up with a solution, I paid for the software and expect a working product.
Try renaming mappoint.dat to mappoint.exe then run the program. You will then need to run mappoint.exe /regserver. This might help.
barry0164 - we are working on a solution.
Jan Bennett
I have faith, Just Like to add i think this is a great Product even without the NAV, Cant wait until fully up and running as i am going to Jersey on Holiday next month and Copilot does not do Jersey (for some reason) but Mappoint does WeyHey.
Working on a better solution. Thank you for your patience.
A new diagnostic tool has been created to help find the cause of the problem. Please see this thread for details.
http://www.mp3car.com/vbulletin/stre...avigation.html
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
This is a great update Chuck!
Thanks for that!
Guys, let us know your results with this new information.
Jan Bennett
nice diag,
used the tool but no did not see the map. As attached;
Tried the tool without and after with the registerbutton used.
The result is the same both times:
screenshot:StreetDeck Navigation Class ID Found in Registry! (7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10)
Mappoint Class ID Found in Registry! (8F78D7FC-BAE4-46A4-A79A-052356AB3DD4)
CoCreateInstance of OLE control ({7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10}) failed. Result code: 0x80040111
WARNING: StreetDeck navigation control creation failed!
WARNING: Failed to create streetdeck navigation object window, trying to create mappoint navigation window!
Map is visible so the error is not in the navigationsoftware?
Unbound error remains.
Hope it helps to solve the issue!
Thanks for the efforts so far!
