Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 68
Thread: UNBOUND #4 for navigation button - 1.0.9.8 (Vista)
  1. #31
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by aceclark View Post
    nice diag,
    used the tool but no did not see the map. As attached;
    Run the attached registry file, if that doesn't work, download the new version of the tool at http://www.streetdeck.com/update/uti...pointTest3.zip run it again and post the new results.
    Register.zip
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  2. #32
    Jan 2004
    Quote Originally Posted by barry0164 View Post
    Tried the tool without and after with the registerbutton used.
    The result is the same both times:
    screenshot:
    Map is visible so the error is not in the navigationsoftware?
    Unbound error remains.
    Hope it helps to solve the issue!
    Thanks for the efforts so far!
    Run regedit from windows. Delete the key HKEY_CLASSES_ROOT\\CLSID\\{7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10}
    If that doesn't work, send me the StreetDeck log.
  3. #33
    Dec 2006
    LONDON
    Thumbs up
    It works,
    Ran Register.zip after the Test program and managed to get the map in the top Left but streetdeck still showed unbound #4 so deleted the key HKEY_CLASSES_ROOT\\CLSID\\{7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10}
    ran Streetdeck and hey presto ! it works.
    Guys thank for your relentless support, if your ever in the uk i owe you a pint or two.
    Many thanks to all at streetdeck
  4. #34
    Jun 2007
    Halsteren, the Netherlands
    Thumbs up
    IT WORKS
    Great job, thanks guys!
    Very happy now
  5. #35
    _
    Mar 2004
    Little Elm, Texas
    great news aceclark!
    bary - let us know how it turns out for you.
    Jan Bennett
  6. #36
    Dec 2006
    LONDON
    What a good start to the weekend.
    Happy Naving
  7. #37
    _
    Mar 2004
    Little Elm, Texas
    issue resolved! thread closed.
    Jan Bennett
  8. #38
    Jul 2007
    Orlando, FL
    Nav button still reads "unbound#4"...
    Hello Guys,
    Sorry, I just got registered as new user, I know you guys closed the thread on this problem. but I am still having the same problem with my navigation button reading unbound #4. When you click on it, it lights up and make a sound, but doesn't do anything esle. I have tried everything you had told the others, but it didn't fix mine. I can open and use mappoint, and I can use all the other features in SD, but the navigation. I have tried uninstalling, and reinstalling both SD, and Mappoint but no luck, I couldn't however delete the registry file because it was not in the my registry. I did download your mappoint APP, and the registry.zip. You APP does say I have some errors, but locks up when I use it, and I don't see the map in the upper corner. Here is what it said....
    Found Mappoint ActiveX control at C:\Program Files\Microsoft Mappoint\MappointControl.ocx!
    WARNING: StreetDeck Navigation Class ID NOT Found in HKEY_CLASSES_ROOT Registry! (7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10)
    WARNING: StreetDeck Navigation Class ID NOT Found in HKEY_LOCAL_MACHINE Registry! (7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10)
    Mappoint Class ID Found in HKEY_CLASSES_ROOT registry! (8F78D7FC-BAE4-46A4-A79A-052356AB3DD4)
    Mappoint Class ID Found in HKEY_LOCAL_MACHINE Registry! (8F78D7FC-BAE4-46A4-A79A-052356AB3DD4)
    CoGetClassObject of OLE control ({8F78D7FC-BAE4-46A4-A79A-052356AB3DD4}) failed. Result code: 0x80040154
    CoCreateInstance of OLE control ({8F78D7FC-BAE4-46A4-A79A-052356AB3DD4}) failed. Result code: 0x80040154
    WARNING: StreetDeck navigation control creation failed!
    WARNING: Failed to create streetdeck navigation object window, trying to create mappoint navigation window!
    WARNING: Mappoint navigation control creation failed!
    FATAL ERROR: Failed to create mappoint navigation object window!
  9. #39
    Jan 2004
    Did you try the register function?
    If your not installing the full version of StreetDeck from the StreetDeck DVD, you should not use the register.zip file. The file locations are in it point to the default StreetDeck installation directory. If you want to use this, you will have to open up the .reg file and rename all file locations so they point to where your copy of mappoint is installed.
  10. #40
    Jul 2007
    Orlando, FL
    Thanks for the quick response.
    I did try the register funtion in your mappoint app a few times, but it just gets locked up. And I ran it as an administrator. So I am not sure what to do next...
    As for the installation, I downloaded the trial version first, then installed the full version of SD from the dvd, which I had to copy over to my harddrive, as I don't have the DVD for my OQO yet. Could this be my problem?
  1. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  2. Power Button not working?
    By NoTicketsPlease in forum Newbie
    Last Post: 02-28-2006, 11:43 PM
  3. Replies: 2
    Last Post: 04-04-2005, 04:45 PM
  4. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
  5. internet button on my pc
    By babas151 in forum General Hardware Discussion
    Last Post: 05-31-2002, 03:41 PM
