1 Attachment(s)
UNBOUND #4 for navigation button - 1.0.9.8 (Vista)
What version of StreetDeck is this bug report for?
1.0.9.8 (Vista)
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
No
If no, please describe your system here.
GPS Rikalin 6010 HP7400 Laptop with Vista Business o/s & Europe edition SD 1024 RAM 80GB HD, Built in soundcard, wifi, nothing else
Are you able to reproduce this bug at will?
No
Please list the steps required to recreate the issue you are reporting.
Please provide any relevent information regarding the issue you have encountered.
Installed sd yesterday full version setup and everything fine except Mappoint does not show on sd (just says (UNBOUND #4) where the button is have setup my GPS Rikalin 6010 correctly as it works when i load mappoint Manually.
When i gesture N it says; Navigation Module is not loaded
1 Attachment(s)
Navigation will not load from Streetdeck - 1.0.9.8 - 1.1.0.0
1.0.9.8 - 1.1.0.0
Yes
Yes
When i open streetdeck the primary screen shows Unbound #4, if i gesture 'N' then it says The navigation component is not installed. (but is is)
i can open New European Map.ptt on its own and all works fine, i did have this problem in Vista and someone on the forum advised does not work with Vista so i downgraded to XP (and still the same problem)
it seems to me that i may have a faulty Disc.?
