me too same problem
What version of StreetDeck is this bug report for?
1.0.9.8 - 1.1.0.0
Please give a basic description of the issue here.
Volume Control Doesn't Work in Vista
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.Move the volume slider up or down to mute and the volume doesn't change. However when I move the slider for the playing media the volume changes. The only way to change the volume is with the Vista volume control in the taskbar.Please provide any relevent information regarding the issue you have encountered.
I originally tested SD on a XP machine earlier this year and it worked so I don't know if it is Vista or my new machine.
me too same problem
Volume still doesn't work in Vista in version 1.1.0.0
I get the same results with the volume with 1.1.0.0
We are aware of this issue with vista and Streetdeck. There is a cheep solution with a griffin powermate for volume control. Other than that we are working on a software solution but this is a lower priority issue due to the low number of vista car PC's. I will report the issue to our developers again. Thank you for the testing and reports!
lol, that thing will look great on my dash, Thanx but I think I will wait and see if it can be done in software wth an update
I have an idea of a temporary workaround. How hard would it be to code a check box in settings that when checked will allow the main volume slider to be directly tied to the playing media slider, because the playing media slider works in Vista. Thanx in advance
Your kidding right?
I used the demo and got some choices of which line to output sound on ... the volume didn't work, but I assumed it was configurable down the road so I didn't mess with it. Now that I purchased SD I find I can't control my volume ? I can't even figure out how to reconfigure the sound output anymore, it's no longer an option. 1.1.0.0
I'd like a refund if that's the case - no point in spending $200 for something I can't even use the volume control in. Isn't volume on of the most important parts of this whole program? I can't reach half way across my cab everytime i want to turn the volume up and down - in a full size truck that's just dangerous. I can't believe this isn't the highest priority at the moment. Rediculous.
Sam
http://www.mp3car.com/vbulletin/stre...oad-links.html
Per the above I show Vista as a supported OS ? Was I mislead ? I wouldn't have bought it if I knew vista wasn't supported.
