can you please try on the newest release (1.1.0.0)?
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
wifi sync. freezes SD
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
When I go to settings, wifi sync, and sync. now, SD freezes and stops responding. I use my ctrl+alt+delete to task manager and it show SD as not responding. I am able to access the shares through regular explorer.Please provide any relevent information regarding the issue you have encountered.
Jan Bennett
any response by the op would be appreciated.
if a response is not recieved within 24 hours, I will have to close this thread due to a lack of response.
Jan Bennett
I apologize, I thought I updated this. I did the upgrade and it is working.
thank you, thread closed.
Jan Bennett
