Results 1 to 4 of 4
Thread: Font Import - 1.1.0.0
    Low Bitrate TheSin's Avatar
    Sep 2006
    Thorsby, AB
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    Font Import
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    here is the error
    WARNING: CFontUtil::Convert - Conversion Failed! The height of the input bitmap (C:\Documents and Settings\TheSin\My Documents\StreetDeck\UI\Skins\Ford\Fonts\Font25.pn g) is not evenly divisible by the number of supported characters (95)
    And I copied them right from the Default theme, any ideas?
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    open a new theme, click import font, select the font, I have tried them all.
    Please provide any relevent information regarding the issue you have encountered.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    The font import tool is for importing font templates. The import tool will take a template and output a font that can be used with StreetDeck. The fonts distributed with StreetDeck are the output of the font import tool and are NOT templates.
    Please see this thread for additional details on creating fonts. The font templates used to create teh default fonts are also linked in this thread. to create a new font, you should modify the font template, then send it through the import tool which will result in the new font.
    StreetDeck Fonts
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Sep 2006
    Thorsby, AB
    ahh I understand now thanks, sorry about the bogus report. I think I have the hang of this skinning stuff now, I hope Spent the last 12hours working on one and only have one small bug thus far that I can see.
    As a side note, is it bad form to make a skin that expects certain digital mods to be installed? Like is that frowned on?
    Quote Originally Posted by god_of_cpu View Post
    StreetDeck Fonts
    _
    Mar 2004
    Little Elm, Texas
    Issue resolved, thread closed.
    I'd ask your question directly to chuck via email or I'd post it in the general discussion are of StreetDeck. We need to keep bug reports clean if at all possible.
    Jan Bennett
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 03:05 AM
  2. Need a font... GE Drover?
    By RoyN in forum Off Topic
    Last Post: 11-24-2006, 08:43 PM
  3. MM font problem continues
    By grnikolis in forum Map Monkey
    Last Post: 07-16-2006, 05:31 AM
  4. Font Type not been used in Phoco Skin
    By RS200Z in forum RR Bug Tracker
    Last Post: 04-21-2006, 09:17 AM
  5. StreetDeck Fonts
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 02-16-2006, 05:21 PM
