Results 1 to 10 of 17
Thread: XM Ignore list clears out after restart of streetdeck - 1.1.0.0
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    Please provide any relevent information regarding the issue you have encountered.
    I can go into XM radio and ignore stations and as long as streetdeck stays open.. even through a hibernate or a standby.. the ignore list is fine.. however i I close streetdeck.. or restart my pc(which closes streetdeck)... the ignore list gets lost.
    Aug 2004
    Pearland
    I forgot to add.. I am using a XM-direct with a serial cable.. and I have XM-direct compatibility checked in the settings...
    I think it might have something to o with the order in which it does things.. it might check the ignore list too soon.. as in before it has finished updating the channel list from the XM-direct...
    _
    Mar 2004
    Little Elm, Texas
    I've just tested this on my laptop with the USB Xm Adapter avaliable here on the store and I cannot recreate it.
    I have SD set to close the program when I tell it to turn off. I even close the tray application before restarting SD. I will see if I can recreate it by completely restarting the laptop, not just SD.
    Jan Bennett
    Aug 2004
    Pearland
    I wonder if it has something to do with the serial cable vs the USB interface then?...
    _
    Mar 2004
    Little Elm, Texas
    Ok - I've just restarted my laptop and station 1 is still ignored on my system.
    Now I have one more test to try. I'm going to remove power to the USB box to see if it's storing settings (I'm testing this on my test bench with my laptop...in the car I'd like to hook to ignition instead of constant).
    Jan Bennett
    Aug 2004
    Pearland
    my XM is powered off the ignition power... and I have a lot more than just 1 channel ignored... I did notice that every now and then when I go back in to ignore channels.. it would have remembered a random channel here and there that was on my previous ignore list ..
    so this might be something more of a bug with a big ignore list?
    _
    Mar 2004
    Little Elm, Texas
    Ok - removed power to the USB adapter and station 1 is still ignored.
    Seems to be either a machine/user specific issue or that the serial cable doesn't handle this feature like it should.
    We need to get someone else who has the same cable to test and confirm their results.
    EDIT: I've also just unplugged USB and power to the device and the stations stay ignored.
    Jan Bennett
    Jul 2007
    I am having the same exact problem with mine also. They channels sometimes default back and none are ignored, but most of the time it is just a channel or two that gets unignored.
    Aug 2004
    Pearland
    Quote Originally Posted by dnatrance View Post
    are you using the serial cable or the USB one?
    Jul 2007
    I am using the mp3car usb
  1. Occasional Song List Hickup with XM
    By chuckster in forum Road Runner
    Last Post: 11-25-2005, 01:09 PM
  2. XM channel list screwing up...
    By Snootch in forum Road Runner
    Last Post: 11-10-2005, 09:37 AM
  3. XM screen shows mp3 list
    By wysocki in forum RR Bug Tracker
    Last Post: 08-17-2005, 10:24 PM
  4. XM Player, Channel List scrunched??
    By KingsDude in forum FrodoPlayer
    Last Post: 05-13-2005, 02:04 AM
  5. List the software you use for XM
    By kickercivic1 in forum Software & Software Development
    Last Post: 12-18-2004, 10:21 PM
