Results 1 to 6 of 6
Thread: Bluetooth GPS connection issue - 1.1.0.0
    Mar 2007
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    When you hibernate and then start the computer back up, SD will automatically pair with the bluetooth GPS.
    However, if you do a standby and come out of standby, it wont pair with the bluetooth GPS.
    Please provide any relevent information regarding the issue you have encountered.
    _
    Mar 2004
    Little Elm, Texas
    Please test this outside of StreetDeck. We need to determine if this is really a StreetDeck bug or if this is an issue with that particular GPS reciever.
    Jan Bennett
    Mar 2007
    ok i tested it out.
    If i hibernate and then return back to windows, my GPS will not automatically pair with my laptop unless i tell blue-soleil to do so (as expected).
    If i hibernate and then return back to SD from hibernation, SD will automatically pair my laptop with the GPS (as expected; SD is a savior and auto-connects).
    If i standby and then return back to windows, my GPS will not automatically pair with my laptop unless i tell blue-soleil to do so. (as expected)
    If i standby and then return back to SD, SD will NOT pair my laptop with the GPS. (unexpected; SD should auto-connect similar with hibernation)
    Mar 2007
    Any updates?
    _
    Mar 2004
    Little Elm, Texas
    Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Please test with the latest release (1.1.1.0) and report back with your findings.
    Jan Bennett
  1. Replies: 7
    Last Post: 04-03-2007, 02:47 PM
  2. Bluetooth phone and GPS
    By dpetteng in forum Centrafuse
    Last Post: 11-03-2006, 07:02 AM
  3. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  4. Replies: 3
    Last Post: 03-31-2005, 07:17 AM
  5. Replies: 0
    Last Post: 01-14-2005, 09:08 PM
