What version of StreetDeck is this bug report for?
1.0.6.3+
Please give a basic description of the issue here.
Phidget Encoder Plug-in Doesn't Stay Enabled
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
1) Phidget Encoder Input Plugin Enabled and Functioning normally.
2) Disconnect Phidget
3)
Power on PC (and StreetDeck) with Phidget disconnected (i.e. PC removed from car for maintenance/updates/etc... phidget "hard-wired" (integrated) into car).
4) Return PC to car, re-attach phidget, power on PC and SD.
BUG: Phidget Encoder no longer enabled. Must be manually re-enabled.
Not sure if this is by design or if the setting/device can be remembered even if it is temporarily disconnected (SD operated with the phidget physically disconnected).... that would be very nice to have!!
Thank you,
Blue
Please provide any relevent information regarding the issue you have encountered.
