Results 1 to 4 of 4
Thread: -DisableWindowHooks not working - 1.1.0.0
    Apr 2007
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    if SD started with -DisableWindowHooks key - it still prevent other programs to start over SD. if press "settings-toggle fullscreen" button, and press it again - then alt-tab working properly, and working before next SD restart.
    Please provide any relevent information regarding the issue you have encountered.
    _
    Mar 2004
    Little Elm, Texas
    I am able to recreate this issue. I will report it to Chuck to find out if this is functioning as designed.
    Jan Bennett
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    The window hooks only prevent certain windows from being shown like license and some login dialogs. The command line parameter is in there for debugging purposes only and doesn't really have much practical use.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    _
    Mar 2004
    Little Elm, Texas
    thanks for the info Chuck. Thread closed. Functioning as designed.
    Jan Bennett
  1. Crossfading does not work. - 1.0.8.1 - 1.1.0.0
    By S4Per in forum StreetDeck Bug Reports
    Last Post: 01-31-2008, 04:12 PM
  2. only odd or only even FM stations - 1.1.0.0
    By Indy in forum StreetDeck Bug Reports
    Last Post: 08-07-2007, 02:24 PM
  3. SPV M700 / HTC P3600 not working with Phonecontrol
    By Tracert in forum PhoneControl
    Last Post: 07-13-2007, 11:16 PM
  4. Anyone currently working with 18f2550
    By lez in forum General Hardware Discussion
    Last Post: 11-03-2006, 08:44 AM
  5. motorized screen stopped working :(
    By corsamel in forum LCD/Display
    Last Post: 11-26-2002, 11:52 AM
