Results 1 to 4 of 4
Thread: only odd or only even FM stations - 1.1.0.0
    Apr 2007
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    if SD started without -RadioTuneEvenStations - only odd FM stations are working. If started with -RadioTuneEvenStations - _only_ even stations are working, not both odd&even. I'm from Russia, here used both even and odd FM stations.
    Please provide any relevent information regarding the issue you have encountered.
    pim
    pim is offline
    Mar 2006
    The Hague, the Netherlands
    tuner autoscan hardcoded to odd frequencies
    1.1.0.0
    Using the command line parameter "-RadioTuneEvenStations", the tune and scan buttons will advance to even frequencies on the builtin tuner in the Infill G4, which is necessary in Europe and probably elsewhere.
    However, the Autoscan menu still searches odd frequencies only.
    Also, IMHO "RadioTuneEvenStations" should be a configurable option in the settings menu rather than a command line option.
    no
    Non mp3car.com Infill G4
    Demo version
    _
    Mar 2004
    Little Elm, Texas
    threads merged.
    Jan Bennett
    Jul 2006
    Baltimore
    This is operating as designed. Making this another button to confuse people in SD rather than a command line parameter would not be good. The likelihood of a car with SD going from the US to europe is not enough to make a switchable button in SD.
  1. Replies: 16
    Last Post: 07-24-2007, 01:03 PM
  2. centrafuse won't search fm stations automatically
    By glenrijke in forum Centrafuse
    Last Post: 01-23-2006, 07:52 PM
  3. FM Radio - remove stations? And line-in mute
    By OrangePeel in forum ME Archive
    Last Post: 11-18-2003, 04:50 PM
