need screen shots and logs to go any further.
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Album art is displayed wrong on a wide screen like the Infill G4, regardless of the "Display Format" setting. Most notably in the "Now Playing" menu, but also in the mini view.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
no
If no, please describe your system here.
Non mp3car.com Infill G4
Please provide any relevent information regarding the issue you have encountered.
Demo version
Jan Bennett
Very well,
Here's sample album art, 300x300
Here's how it looks in Streetdeck, windowed mode. Looks OK.
But the problem is in fullscreen mode. Album art is really stretched.
log file
Pim
Thanks for the images and the log!
Jan Bennett
This is operating as designed. SD resolution and album art corresponds to the resolution setting of the graphics card.
I have to disagree with this based on my usage. When I'm using SD in 16:9 aspect in my car or on my widescreen laptop, nothing appears stretched like in his screenshot.
I tried SD on a desktop PC with a 1600x900 widescreen display.
I see the same album art stretching as on the Infill G4. Viewing pictures using the Pictures menu also shows stretched pictures.
On this PC, I also had the opportunity to see what the effect is of the "Display Format" setting (16:9 vs 4:3). It has no effect on album art and picture viewing.
It does have an effect on playing video's. The aspect is right if you set it to 4:3 on this 1600x900 screen with 16:9 resolution and 16:9 size. Video's show too narrow if you set it to 16:9.
This is confusing. What the setting really should be called is "wide pixels" versus "square pixels". It should only be set to 16:9 on a screen with 4:3 pixel resolution and 16:9 physical dimensions.
But again this is for video's only. Pictures and album art are always stretched on a widescreen display with square pixels. This is inconsistent in the way SD handles videos.
Pim
...I just ended up "stretching" the buttons vertically to compensate for the horizontal stretch that Streetdeck does when it gets put into widescreen. It looks funny in windowed 4:3...but fine in fullscreen 16:9.
