Results 1 to 5 of 5
Thread: Display settings not saved
    pim
    pim is offline
    Mar 2006
    The Hague, the Netherlands
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    Display format under settings->general->display options is not saved. It always starts with "normal (4x3)".
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    no
    If no, please describe your system here.
    Non mp3car.com Infill G4
    Please provide any relevent information regarding the issue you have encountered.
    Problem is similar to this problem but different, as the solution presented there does not apply to this install.
    This install has been setup from a recent setup.exe, which allows the user to select platform (non-Infill/Infill T3/Infill G4). Having chosen Infill G4, T3devControl.dll does not exist on this system.
    log
    Pim
    Apr 2007
    San Dimas, Cali
    I have the same problem on my G4 from MP3Car.com. This function has never stuck for me in any version.
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by god_of_cpu
    The display is never stretched since the G4 uses a widescreen display at a widescreen resolution. The option is only for widescreen displays that do not run at a widescreen resolution.
    Jan Bennett
    pim
    pim is offline
    Mar 2006
    Thanks. That's cleared up now.
    I actually was only trying this to see whether it has any influence on the album art stretching I reported in another thread.
    Issue resolved.
    Pim
    _
    Mar 2004
    Little Elm, Texas
    Thread closed.
    Jan Bennett
  1. V1 Virtual Display : Skinnable Valentine One to PC Software
    By zPilott in forum Software & Software Development
    Last Post: 01-18-2013, 06:11 PM
  2. Planning Phase help for ceiling mounted display
    By HullBreach in forum Newbie
    Last Post: 04-07-2007, 05:31 PM
  3. Centrafuse XLE RC1 Release Notes
    By veetid in forum Centrafuse
    Last Post: 07-12-2006, 04:48 PM
