Results 1 to 7 of 7
Thread: FM Tuner skips many frequencies - 1.1.0.0 - 1.1.1.0
    pim
    pim is offline
    Mar 2006
    The Hague, the Netherlands
    What version of StreetDeck is this bug report for?
    1.1.0.0 - 1.1.1.0
    Please give a basic description of the issue here.
    Tuner control buttons always advance or decrease FM frequencies in 0.2 MHz increments, thereby missing half of available radio stations. This applies to the "tune" and "scan" buttons in the tuner menu, and the "autoscan" menu under settings. Using the tuner slider is it possible to select almost, but not all frequencies.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    No
    If no, please describe your system here.
    Non mp3car installed Infill G4.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    Select AM/FM Radio, select FM, press the "Tune +" button. The tuner will advance 0.2 Mhz and possibly miss a station only 0.1 MHz away.
    Select Show Tuner, use the slider and slide to 92.0 MHz. Slide slowly to 93.0 MHz. Every intermediate frequency is shown, in 0.1 MHz steps, except 92.8 MHz.
    Please provide any relevant information regarding the issue you have encountered.
    There appears to be no commandline option or setting that alters this behaviour.
    _
    Mar 2004
    Little Elm, Texas
    Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
    Jan Bennett
    pim
    pim is offline
    Mar 2006
    Unfortunately, the problem has become worse.
    Increments are still 0.2 MHz rather than 0.1 MHz in the scan functions.
    But the previous version featured a slider at the bottom that would allow one to select almost any frequency. This slider is now replaced by one that also uses 0.2 MHz increments consistently.
    The keypad allows odd frequencies to be entered only, regardless of the -RadioTuneEvenStations command line option.
    Pim
    _
    Mar 2004
    Little Elm, Texas
    thanks for the update - original post and thread title updated.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Please retest with the latest release (1.1.1.0) and report back with your findings.
    Jan Bennett
    pim
    pim is offline
    Mar 2006
    No changes.
    Pim
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by pim View Post
    No changes.
    Pim
    I know this is an older post, but did SD version 1.1.1.6 fix your problem? Worked for me
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  1. HQCT software development
    By Putput in forum Software & Software Development
    Last Post: 06-10-2010, 03:33 AM
  2. E46 Rubbish Radio Reception, whats the best fm tuner?
    By Craggy in forum General Hardware Discussion
    Last Post: 05-18-2007, 06:54 AM
  3. XM and FM tuner
    By pshadwick in forum Newbie
    Last Post: 03-09-2006, 06:45 PM
  4. FM Tuner Card, or remove hu?
    By gareva1 in forum Car Audio
    Last Post: 08-16-2005, 09:55 AM
  5. Replies: 2
    Last Post: 04-10-2005, 12:18 AM
