Please run with -verbose and post another log.
Does it eventually come back if you wait a while? Sometimes some devices can take a while to come out of hibernation and StreetDeck will wait for them until they do.
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
When I have a script installed that uses CreateHostWindow, then when coming back from hibernate I get a black screen, and music has stopped.
During this time, the buttons (which you cant see) in streetdeck still work. When you press them they make the button press noise.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Infill G4
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
1) Load basic sample http://www.mp3car.com/vbulletin/stre...1-1-0-0-a.html
2) Install it on SD pc
3) Load SD
4) Turn car off (Go into hibernate)
5) Turn car on
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
Here you go.
No doesnt come back.
buttons still work
In this log:
*load
*start playing audio file
*turn off car
*turn on car
*black screen
*press black area where buttons are to shutdown
Does it work if you rename your my documents\StreetDeck\Scripts directory?
You are correct Chuck.
By renaming the scripts directory, SD does return from hibernate correctly.
I have moved this thread to the bug form as I have been able to replicate the error with a sample plugin.
Get the sample from here
Looks like the issue affects any plugin that uses CreateHostWindow()
Please edit your first post to reflect the proper bug reporting form.
Just go to another bug report and copy the form over. We need this informatio in the first post to make tracking easier.
Jan Bennett
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
Please retest with the latest release (1.1.1.0) and report back with your findings.
Jan Bennett
Im away over xmas so testing is not that easy.
However after a quick test it does seem to be working correctly.
YAY!
thanks.
black screen when resume from hibernate on 1.1.1.0 on Vista
