What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
SD hangs on startup after rebooting. About 1 out of every 5 times I reboot, SD will lock up. It appears from the log to be trying to start the media player. When SD starts up normally, everything seems to work fine, plays music, movies, navi OK, etc.
Windows Media Player version 11
In case it matters, I do have ITunes installed but no IPOD attached.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Please list the steps required to recreate the issue you are reporting.
Keep rebooting computer and after a several tries it will hang.
Please provide any relevent information regarding the issue you have encountered.
Jan Bennett
Please retest with the latest release and report back with your findings: Download StreetDeck Updates
Jan Bennett
Not able to duplicate the problem...
I couldn't figure out how to resolve the WMP hang issue, so I upgraded to a new laptop with a fresh XP install. Haven't seen the problem since.
Thanks for the heads up on the new release.
Thread closed.
Jan Bennett
