Results 1 to 10 of 11
Thread: video problem
    Apr 2007
    NE ITALY (near Venice)
    video problem
    What version of StreetDeck is this bug report for?
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Please list the steps required to recreate the issue you are reporting.
    Hi, when I try to see a video for the first time after I had copied the file I click on play and I see the video, after that I stop the video and play music or other, If I return to the video SD ask me if I whant to resume the video or restart, I click one of two and I don't see the video the audio is flashing, why I have this problem??
    thanks
    _
    Mar 2004
    Little Elm, Texas
    I have edited your post to reflect the current bug reporting form that's used. Please fill it out appropriately.
    Also, as with any bug report, we need a log file to continue any further.
    I'm not sure I understand this comment:
    Since 'audio' is sound, I'm not sure how the sound is flashing. Perhaps you mean the video is flashing?
    Are you able to recreate this issue on any other PC?
    Can any other replicate this issue?
    Jan Bennett
    Jun 2007
    NJ
    I dont have a log file but Yesterday I tried messing with my streetdeck because I have the intentions of playing more music videos in my car. I have come to realize it's pointless. I don't know if its my setup or what but I can have a music video play fine but once it finishes it locks up, if i stop it and go back and try to click replay I get the audio with a black screen. If i go back and select a different video it locks up.
    Mar 2005
    I was having all sorts of problems with Xvid/Divx playback with mine...and I just ended up installing the latest Xvid codec - http://www.xvidmovies.com/codec/ and it seem to cure all the problems I was having, plus it seems like the video looks better (blockiness is gone) than with the codec that comes from SD Ffdshow.
    Jun 2007
    NJ
    Quote Originally Posted by Tranman View Post
    Whats up, this is music to my ears and I will try it in the morning. did you have to uninstall anything or did you just install that codec pack?
    Mar 2005
    Didn't need to uninstall...just installed the Xvid codec from the link...
    Apr 2007
    I have tried with your codec mr. tranman, but don't resolve the problem I have discovered that problem appear only with the file of big dimension, because I have tried with one of 700Mb and the video remain black and the audio is intermittent with file of 22 mb are all ok.
    I think that is a problem of software because sometime when I try to open a video of 22mb the SD open another window under the SD video module in that window there is playng video
    Jun 2007
    NJ
    Quote Originally Posted by giannidsg View Post
    Odd because I didnt get a chance to install the codec pack yet but my sd has the same issue your having but with music videos that are 50-100mb
    Mar 2005
    Hmmm, seems like I'm experiencing these types of problems again. It looks like the DirectX rendering engine isn't properly redrawing the video file within the Streetdeck window...I'm having issues with video tearing.
    _
    Mar 2004
    Little Elm, Texas
    Please retest with the latest release and report back with your findings: Download StreetDeck Updates
    Jan Bennett
  1. Jetway Onboard Video Problem
    By at4wd in forum General Hardware Discussion
    Last Post: 08-16-2007, 07:18 PM
  2. Video problem (maybe) RR 9-5-06
    By vinzer in forum Road Runner
    Last Post: 09-09-2006, 01:29 AM
  3. Video playback problem - laptop car pc
    By 12345car in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 05-12-2006, 03:41 PM
  4. FV24 wasted space on video out problem
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-22-2002, 07:20 PM
