Results 1 to 8 of 8
Thread: Navigation slow to resume after hibernate - 1.1.0.0
    Aug 2007
    What version of StreetDeck is this bug report for?
    1.0.9.8-1.1.0.0
    Please give a basic description of the issue here.
    Usually (with only a few exceptions) Navigation has low signal for 1-5 (or more) minutes.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    Reproduceable?
    On my computer...
    Please provide any relevant information regarding the issue you have encountered.
    If I start streetdeck after a system reboot, nav shows my position immediately. After hibernating, it usually takes a while for the nav to get a signal. There is ALWAYS a delay after resuming from hibernate. Occasionally, the GPS starts after 30 seconds. A few times, it has literally taken more than 5 minutes before I lost patience and rebooted. I would say the average time is 1.5 minutes. I know that my GPS receiver is working properly, because I immediately have signal when starting other GPS applications (Including my copy of MapPoint).
    Attached Files Attached Files
    _
    Mar 2004
    Little Elm, Texas
    you state that the informtion under your user name is the information about your CarPC but there is no information under your user name. Please fill it out according to this thread: http://www.mp3car.com/vbulletin/anno...r-profile.html
    Jan Bennett
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    i get the same result, and IMHO this bug should be a lot higher severity than 3!
    Just dug into it over the last couple of days. I've had it take 15 minutes to get signal back (i.e. to get Nav not to show 'low signal from GPS') and if I exit SD and restart SD, it picks up signal right away.
    I don't have log, but you have one above.
    Navigation is a key piece of this software. If it's not up and running sub 30 seconds of a computer start or resume, it's useless. It worked better in the past.
    _
    Mar 2004
    Little Elm, Texas
    S4Per - one or two users reporitng an issue does not necessitate a higher priority on our developers list. Many times, when only one user is reporting an issue it's a user or a configuration error.
    Only once bugs are reproduced by our team or are verified by other users can we re-evaluate and raise the severity level.
    Jan Bennett
    Jan 2004
    Seattle, WA
    Thanks Jan, I understand. As I mentioned, "IMHO" :-)
    _
    Mar 2004
    Little Elm, Texas
    Please retest with the latest release and report back with your findings: Download StreetDeck Updates
    Jan Bennett
    Aug 2007
    Car totaled, and mobo destroyed....will be a while before I can test
    _
    Mar 2004
    Little Elm, Texas
    thread closed then.
    Jan Bennett
  1. Problem: Standby, Hibernate, can only resume once
    By wuzzaap123 in forum General Hardware Discussion
    Last Post: 08-30-2006, 11:19 AM
  2. hibernate issues being slow
    By toxsickcity in forum General Hardware Discussion
    Last Post: 08-15-2005, 12:00 PM
  3. m10000 doesnt always resume from hibernate
    By fasternfaster in forum General Hardware Discussion
    Last Post: 11-29-2004, 03:21 PM
  4. Voice activated navigation for routis!
    By 0l33l in forum PowerVoice
    Last Post: 10-03-2004, 03:39 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
