Results 1 to 6 of 6
Thread: Less Virtual Earth modes available - 1.1.0.0
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    The virtual Earth button in navigation used to have 3 modes. Aerial, Hybrid and Map. Now it ONLY has hybrid. I suppose that was not intentional.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the issue you are reporting.
    Just go to the navigation screen and click the Virtual Earth button! It happened to both my installation on the same system. ( I'm transitioning to a clean install )
    Please provide any relevant information regarding the issue you have encountered.
    The template is NOT working for bug reporting (irrelevant)
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
    _
    Mar 2004
    Little Elm, Texas
    The template not working is a known issue for some time now and is being worked on.
    Thank you for thinking ahead and utilizing the resources at your disposal to create a bug reporting using the format.
    Jan Bennett
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    There is an option in navigation settings to show extended virtual earth modes. Check it.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    _
    Mar 2004
    Little Elm, Texas
    Thanks for the info Chuck!
    Spaceskater - please report back with your findings.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Please retest with the latest release and report back with your findings: Download StreetDeck Updates
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Thread closed as this is not a bug.
    Jan Bennett
  1. How About...A Virtual CD Changer
    By chuckster in forum Road Runner
    Last Post: 09-23-2011, 02:03 PM
  2. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 08:58 PM
