Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: music not indexing - 1.1.0.0
    Oct 2007
    orlando fl
    What version of StreetDeck is this bug report for?
    1.1.0.0
    Please give a basic description of the issue here.
    music not indexing
    Is the system that is listed in your CarPC specs under your username the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Infill g4
    when i add new music to my car hard drive in my music folder, streetdeck dosnt see it. when streetdeck starts up it says no new files. to get it to see it i have to go and clear the music files and tell it to do a total re index.
    yes bug can be replicated 100% of the time and others are having the same issue see thread here:
    http://www.mp3car.com/vbulletin/stre...-new-post.html
    Are you able to reproduce this bug at will?
    Yes
    Please list the steps required to recreate the isse you are reporting.
    add any new music to the my music folder.
    turn on streetdeck.
    logo at top says no new music found
    to get music to index you have to go under settings and reindex manually , clearing the old index, which also clears the playlists.
    Please provide any relevent information regarding the issue you have encountered.
    note post in original desciption, many other peole also haveing the same issue
    Elsewhere
    I experience the same issue with v1.1.0.0
    How about the Wiki?
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Under Music settings, scroll down to the bottom and make sure that the check box for "Automatically index and move music files when Streetdeck starts" is checked. When I installed one of the latest updates, it reset several of my settings, and that box was unchecked even though I had it checked before I installed the update.
    Elsewhere
    We've been through that already, Nola.
    How about the Wiki?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Are you sure you are placing the files you want indexed in the StreetDeck Import folder? The functionality changed a while back so that it will not index new files in your music folder and move them, rather it will just look for files in the StreetDeck Import folder and move them to the music folder when indexing them. Use the StreetDeck media paths tool to verify your paths.
    I have tested this and it works. I don't have 1.1.0.0 handy though so it could of been inadvertantly fixed.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Oct 2007
    orlando fl
    yes, 1st thing i made sure of. remember if indexes them correctly if i delete the database and tell it to do a manual index
    Jan 2004
    The manual indexing indexes from the music path. The auto indexing only indexes from the StreetDeck Import Music path. They are different paths. If your manual indexing is working and the auto indexing is not, it probably because you don't have any files in the import path the auto indexing uses or you have change the path it uses with the Media paths tool.
    Oct 2007
    orlando fl
    just walked out side and TRIPPLE checked the indexing and the music folder
    Jan 2004
    This has been confirmed as a bug in 1.1.0.0. It will be fixed in the next update.
    Oct 2007
    orlando fl
    thanks, wow i am surprised i was the 1st to put a bug report in about this.
  1. Music Indexing Failure in 1.0.9.8
    Last Post: 07-07-2007, 07:07 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  3. Problem music plays with video
    By john05srt4 in forum Road Runner
    Last Post: 01-02-2007, 08:51 AM
  4. Buffer overruns when indexing music
    By belezeebub in forum StreetDeck
    Last Post: 10-02-2006, 04:47 PM
  5. No auto resume music and video?
    By organasised in forum Road Runner
    Last Post: 02-10-2005, 09:55 PM
